Help with SCREECHING ALT BELT !!!
Old May 13, 2007 | 08:49 PM
flacoz_da_king's Avatar
flacoz_da_king
Default Help with SCREECHING ALT BELT !!!
I have a 98' dodge Neon with annoying alternator belt screeching. Use to only screen when I first crank the engine, now it screeches when I'm driving. Someone give me visual aid or instructions please...
Old May 14, 2007 | 05:35 AM
03neonRT's Avatar
03neonRT
Default RE: Help with SCREECHING ALT BELT !!!
I would try and visually inspect the belt to see its condition (cracks, etc...)...also, you may need to just tighten the belt...On a 2nd Gen this process is very simple, but I'll let a 1st Gen guru chime in with instructions...
Old May 15, 2007 | 02:03 AM
billie5769's Avatar
billie5769
if you push on the belt, it should move no more than about a half inch. The alternator should have an tensioning adjuster bolt on it. Also, if you have an oil leak in that area, the belt may have oil on it causing it to slip.
