Rebuilding Chrysler’s 2.0L Engine
Old Sep 26, 2007 | 08:44 PM
Durnald_Toad's Avatar
Durnald_Toad
Default RE: Rebuilding Chrysler’s 2.0L Engine
Cool, now where can I find new vaulves and springs for a Magnum motor ? Seems
And you say befor ? What are you running now das2123 ?
Old Sep 27, 2007 | 08:24 AM
das2123's Avatar
das2123
ORIGINAL: Durnald_Toad
Magnum springs from the dealer are pretty reasonable....about $50-$60 if I remember correctly.
My ACR is stock except for the new CNNP Race Ported head I just swapped onto it (has the magnum springs in there as well). My idler pulley failed, snapped and shredded my timing belt and belt some valves, so I put the head on there.
Old Sep 27, 2007 | 04:21 PM
Durnald_Toad
Sounds fun to drive das2123.
[sm=gears.gif]
Also sounds like you know Neons.
I've found this->
Magnum Valves:
intake, 7 bucks a pc.
exhaust, 10 bucks a Pc.
Mag Cam; $222
TheMagnum motor has bigger valves than my 97 SOHC
I see the words " plug and play" is this true for swap'n valves after a little bore ?
I just ordered the magnum valve springs... 16 of them
Now this valve mith has me thinking. Are my valves bad ?
Don't care if they are bad, if I can get more HP out of bigger valves sweet.
Old Sep 28, 2007 | 08:21 AM
das2123's Avatar
das2123
Well considering they are both SOHC, I would think you could swap them in. But I don't know anyone that has taken that route.
Old May 24, 2008 | 01:33 AM
Durnald_Toad
It's time for a camshaft.
No valve jobs...
I have seen the COMP Cams and I'm not sure if I can use the one for the RT.
After reading this post as a reminder, I remembered that the R/T cam looked good! (It's been awhile!)
So I guess the 2001 R/T camshaft is the BEST choice for a 97 SOHC? I think this is a drop in too ?
And I need new springs ? (The ones I ordered never came, I could have sent Chuck Noris to the bank over this stupid daily limit rule.)
I will be orderinga camshaft with in the next week or so.
ANY feedback is welcome !!!
Old May 24, 2008 | 01:36 AM
12 volt's Avatar
12 volt
wouldnt that be a magnum cam?
Old May 24, 2008 | 01:51 AM
95to96transplantneon's Avatar
wow this was dug back up from the grave...
Old May 24, 2008 | 01:59 AM
Durnald_Toad
Yeah,
I think it is the Magnum motor.
This was dug up from the grave. Things happened a put a pause on my project...
But, there are any more cars out there that need to be out ran by a Neon Haahahahahahaaa
So as of now I plan on getting a 01 R/T Magnum Camshaft for my 97 SOHC
Old May 24, 2008 | 02:07 AM
To answer your question yes the 01 - 02 RT cam is the magnum cam... its slightly hotter of a cam then the 95... 6-10hp gain from your stock cam... Depending on your current air flow mods...
Old May 24, 2008 | 02:17 AM
Durnald_Toad
So whats the best Cam for the 97 SOHC w/ high flow intake and exhaust ? (header, CIA, catback.. )
The COMP cam offers 12-14 HP at wheels, but is says for R/T or ported heads...
