A/C recharge
Old May 16, 2007 | 10:59 PM
iwalton63's Avatar
iwalton63
Default A/C recharge
i just got one of thos A/C recharge cans. and read all the instructions and did them the way it said..but when i hook it up to the car i get the reading of about 9 psi on the gauge ( thats really low) and it says to leave it on there for 5 to 15 minutes.... so i did, and the can just didnt seem like it was getting any lighter. and the gauge wasnt showing any improvement or anything. i took it back off and nothing came out. like the can was still completley full,
so has anybody got one of these things to work./ had the same problem i am having?
any feedback what be awesome
thanks
Old May 16, 2007 | 11:07 PM
neonracer1010's Avatar
neonracer1010
Default RE: A/C recharge
is your can getting cold or anything like that
try sticking a paper clip in the little valve where u screw the kit onto and relase some pressure and then try again. also lub tek a racing motor oil company makes an oil called dyno K or dyno Q either or, designed for kart racing that we use in our go karts. try pouring a very little bit of that down into there it makes it stop leaking as fast, you could probally use a similar oil as well, as long as it is very lite weight.
Old May 16, 2007 | 11:19 PM
jakedlee16's Avatar
jakedlee16
turn it upside down for a few minutes .. make sure the system is running .. and give era couple good revs while the ac is on full blast
Old May 16, 2007 | 11:33 PM
iwalton63's Avatar
iwalton63
nevermind got it to work now the the pierces the can was bent somehow but i bent it back and it works fine. thanks guys
