neon electronics dead
Old May 17, 2007 | 02:47 AM
fordboy_52's Avatar
fordboy_52
Default neon electronics dead
i was driving and hit a small mud puddle with some water in it and the car died, no electronics work right. the radio and cig lighter work when the key is on all the way back. put it forward on run and nothing works. the gas guage only goes up half way and it is full. no start or click
any ideas?
Matt
Old May 17, 2007 | 03:05 AM
das2123's Avatar
das2123
Default RE: neon electronics dead
May have shorted something...check all your fuses and relays. Did the battery get wet?
Old May 17, 2007 | 04:50 PM
fordboy_52's Avatar
fordboy_52
nope, just the bottom of the motor. fuses look fine
Old May 17, 2007 | 05:24 PM
das2123's Avatar
das2123
So what happens when you turn the key?
Old May 18, 2007 | 01:20 AM
fordboy_52's Avatar
fordboy_52
when i turn the key everything dies like it has a dead short or and open
i unhooked the post going to the starter and it still does the same thing. when i shift from park to neutral, the gauges all die like its shorting out. and when i tried to start it regardless how, the starter fuse is BUZZing pretty good inside. this thing is driving me bonkers.
im curious if there is a sensor in the tranny that is bad? im lost
Old May 18, 2007 | 02:05 AM
fordboy_52's Avatar
fordboy_52
reverse lights work.....
Old May 18, 2007 | 08:27 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
which side of the car did you hit the puddle on?
Old May 19, 2007 | 01:48 AM
fordboy_52's Avatar
fordboy_52
ill be damned, changed the battery and now it works. i broke the battery inside i guess..... still readys 12.7 volts until you load it
Matt
