Car Stereo info
Old May 19, 2007 | 12:53 AM
rother101's Avatar
rother101
Default Car Stereo info
Hey, I recently purchased a '97 Neon, and I wanted to know if I am able to connect my ipod directly to the stereo. There isn't a cassette deck, or CD deck and therefore I have no idea how to connect it. I would buy a deck but I have no clue where I could put it. It doesn't look like there is any spot where I can put it on the front. Thanks, help would be greatly appreciated.
Erich
Old May 20, 2007 | 06:23 AM
neisg1's Avatar
neisg1
Default RE: Car Stereo info
I picked upan FM transmitter on ebay for my MP3 player. It's powered from the cigarette lighter socket and transmits to the FM radio. It was only around $20.00 on ebay.
Old May 24, 2007 | 01:28 PM
das2123's Avatar
das2123
Think about it...in 97 the iPod wasn't around, so do you really think there is a connection for it on the stock radio?
Get an aftermarket stereo and put it in place of the stock one.
Old May 24, 2007 | 01:50 PM
estneon's Avatar
estneon
lol good one das,get a aftermarket head unit i installed a light weight head unit in my stratus to 'shed a few pounds'
Old May 25, 2007 | 03:04 AM
neonracer1010's Avatar
neonracer1010
light weight?
ORIGINAL: rother101
Erich
what do you mean by that. you take the stock radio out
Old May 25, 2007 | 03:32 AM
estneon's Avatar
estneon
i missed thatlol....better take care of the next ? you turn the **** to turn the volume up
Old May 25, 2007 | 12:13 PM
das2123's Avatar
das2123
ORIGINAL: neonracer1010
Are you serious? It's held in with 2 screws, take those out and pull the radio out. It isn't welded in there.
Old May 25, 2007 | 07:06 PM
estneon's Avatar
estneon
off topic a little but it can be hard on some cars my 69 bonneville it takes about an hour to remove thankfully it a convertable so its easy to get in and lay on my back and work on it.....but it a neon remove the cover by pulling it then unbolt 2 bolts maby 10mm and pull it out pull the connectors and your done installing a new one is kinda hard with the splicing of the right wires i didn't have my stratus right for threetrys but it was my first time doing it now itlooks good and sounds good.
Old May 25, 2007 | 08:20 PM
das2123's Avatar
das2123
^^^If you get a wiring harness it's easy. The wires are color coded, so it's real easy if you aren't color blind.
Old May 25, 2007 | 08:35 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
yeah cutting the stock harnes is just retarted when the wiring kit is only 20 bucks and you can swap the stock one back in in under 2 min
