smog so no turbo..all bolt ons
how much horse power could i expect with headers, 55tb, msd blaster coils, aem intake, mopar cams, mopar ecu, under drive pullys. i dont really want to get a turbo because of smog test and also i dont really want to spend 3,000..o yea 1998 r/t neon 5 speed
the throttle body just increase throttle response and then coil really won't do that much performance at all
for the AEM cold air intake just build a custon 3.0L intake
if you dont know how to just search "3.0 cai" in the search field at the bottom
the AEM will give you maybe 3-4 because it's an open filter
and the 3.0 one will give you like 7+...probably not..hahahah
but theres a big difference
you'll get the most power out of the ECU
but neoncrazy is pretty much right about hte hp maybe a little more maybe a little less
ORIGINAL: neoncrazy101
155-165 maybe.
155-165 maybe.
so basically you might be looking at about 150-155 at the wheels
ORIGINAL: spudsterier
at the crank......the r/t's make 150 stock, but thats at the crank too
155-165 maybe.
155-165 maybe.
so basicly i need to boost it to see the biggest differnce..but its also a daily driver and i do long trips so maybe 5-6 pounds of boost. and i might get a hook up for smog
Trending Topics
no real big imprpvements with those bolt ons huh well i just thouhgt that i would not have to worry about blowing my motor with a turbo and getting it to run right
