lost all power what did i do
Old May 21, 2007 | 10:29 AM
tthus111's Avatar
tthus111
Default lost all power what did i do
was getting code 35 on 97 sohc replaced rad fan relay, hooked battery back up, started engine, checked codes with obd scanner then erased code 35. then when i turned key to restart car i heard a small sound like "poof" and then had no power whatsoever. everything is dead, no lights, radio, wont even crank. like trying to start a car without battery. im assuming that "poof" sound was not a good sound. i checked all the red green yellow fuses and the all look good. could i have fried one of the black cube lookin things? anyone have any suggestions?
Old May 21, 2007 | 10:32 AM
tthus111's Avatar
tthus111
Default RE: lost all power what did i do
or did i fry something really bad. any suggestions on where i should start my search?
Old May 21, 2007 | 01:08 PM
das2123's Avatar
das2123
Did you hook the battery back up correctly? First thing to check is the battery.
Old May 21, 2007 | 06:21 PM
tthus111's Avatar
tthus111
i started the car and let it idle until the fans kicked in to make surerad fans were working. theycame on,(afterabout 10 minutes)then i turned car off and then checked codes with obd scanner. it was only after i cleared code 35 and then tried to restart that it make the poof sound. rechecked cables clean and tight. dont know where to start checking.
Old May 22, 2007 | 12:23 AM
das2123's Avatar
das2123
So have you had the battery checked after the "poof" sound?
Old May 22, 2007 | 04:18 AM
tthus111's Avatar
tthus111
no i didnt check the battery it self just the connections( posts) do you think it might of been the battery itself? i dont know much about electrical stuff, just figured it might be a fuse or something. would the battery itself lose power immediately if it blew? and is it a common thing for a battery to go like that?
thanks TTHUS
Old May 22, 2007 | 11:14 AM
das2123's Avatar
das2123
ORIGINAL: tthus111
Common..probably not, but not unheard of. One time I took my battery off to do some work in the engine bay. Put it back on and nothing. Took it in to get tested and it was dead [X(]. Got a new one and threw it in there and it fired right up. Don't know what the hell happened to the battery, but it was working fine before I pulled it out.
Old May 22, 2007 | 09:45 PM
rrwertz's Avatar
rrwertz
check the fuses under the hood. you don't have power now to anything? no fuel pump noise? can you jump the car?
Old May 25, 2007 | 09:18 AM
tthus111's Avatar
tthus111
sorry it took me so long to get back to ya. workin 12 hr shifts with holiday coming up. i get no noise at all, no pwer to anything. i dont even get click when i turn the ignition key. but i did notice when i turn the key the fuel gauge bar moves just a little. ( thats the only evidence i see of any power)checked the fuses they all look good. but what do those little black cubes do?
Old May 25, 2007 | 12:17 PM
das2123's Avatar
das2123
ORIGINAL: tthus111
Those would be your relays. I'd get your battery checked first and foremost.
