intake manifold
Old May 22, 2007 | 09:15 PM
winplet1971's Avatar
winplet1971
Default intake manifold
i have a 96 neon with a 2.4 dohc looking for an aftermarket intake manifold and a computer it has the stock 2.0 puter in it now runs well but slow on take off and running way to fat any info or help please
Old May 22, 2007 | 09:36 PM
rrwertz's Avatar
rrwertz
Default RE: intake manifold
if it's running rich, take it to the dyno and tune it. get a wideband and do it yourself. fix what you can before spending money on something you may not need.
my 2.4 has no problem off the line with a stock 2.0 computer. unless you have cams you won't rev high enough to warrant spending on an ecu. plus you'll have to run 93 and gas is ridiculous. what cams are you running? stock 2.4 cams suck. replace the springs and retainers and run bc or at least crane 16's. that's the best thing to do to a 2.4
Old May 22, 2007 | 09:39 PM
winplet1971
i have after market cams,after market springs and retainersreally dont kick in till 3,000 rpm
Old May 22, 2007 | 09:41 PM
rrwertz's Avatar
rrwertz
what kind?
Old May 22, 2007 | 09:45 PM
winplet1971
id have to ask the guy i bought it from i know they are a mid ranger cam and on the freewway it runs awesome
Old May 22, 2007 | 09:58 PM
winplet1971
ok well what if i switched out the man trans throtle body with an auto trans t.b. i know there is a 4 to mm diffrence and ported and polished the stock manifold ,is it worth it to go that route?i for got to tell you it also has 24 lbs fuel injecters
Old May 22, 2007 | 11:41 PM
das2123's Avatar
das2123
Swap in the ATX TB (52mm as opposed to 49mm) and enjoy the better throttle response. Port and polish your stock manifold.
http://www.angelfire.com/space/neon/porting.html
Old May 23, 2007 | 01:27 AM
AMM's Avatar
AMM
i can build u an intake manifold
