2.4l swap Help!!!!
Old May 24, 2007 | 11:50 PM
jeanpierre's Avatar
jeanpierre
Default RE: 2.4l swap Help!!!!
how will i wire the engine if i use the neon tranny
will i have to use the pcm from the stratus? cause i got all that junk
Old May 24, 2007 | 11:52 PM
jeanpierre's Avatar
jeanpierre
i was trying to use the stratus pcm and tranny cause then i will have the power that its desing to have without cutting on it
Old May 24, 2007 | 11:55 PM
das2123's Avatar
das2123
ORIGINAL: jeanpierre
You need a DOHC ATX PCM and you are good.
Old May 25, 2007 | 12:00 AM
das2123's Avatar
das2123
Both engines are rated with the same HP, its the torque rating thats different.
Old May 31, 2007 | 12:52 AM
jeanpierre's Avatar
jeanpierre
where can i buy the mounts and i need an intake Got one ?
Old May 31, 2007 | 11:57 AM
das2123's Avatar
das2123
Modern performance sells the 2.4 motor mount adapter. You need an air intake or an intake manifold?
Old Jun 5, 2007 | 10:02 PM
jeanpierre's Avatar
jeanpierre
and intake manifold
Old Jun 5, 2007 | 11:23 PM
das2123's Avatar
das2123
You can use a intake manifold from a 2.0L DOHC neon.
Old Jun 9, 2007 | 02:41 AM
jeanpierre's Avatar
jeanpierre
thanks
Old Jun 9, 2007 | 11:03 AM
rrwertz's Avatar
rrwertz
it's the easiest swap in the world. even easier than a hondas.
