alternator bolt spinning in place?
Old May 26, 2007 | 04:25 AM
pssssst's Avatar
pssssst
Default alternator bolt spinning in place?
okay so im replacing the cam seal on my 96 sohc... i got all the way to where the 2 alternator bolts need to be loosened so the belt will come off.... but for some reason the bottom bolt was the biggest pain in the rear ever to break loose, and now its spinning in place... what the heck should i do? anybody else have this problem???? thanks to all who post
Old May 26, 2007 | 05:14 AM
prplhaze's Avatar
prplhaze
Default RE: alternator bolt spinning in place?
Well...the backside of the bottom alternator bolt came with a weird looking nut from the factory.I think it was supposed to stay in place somehow the whole time, so all you have to do is turn the bolt to tighten.I would recomend using a lock nut in place of that.The factory nut seems to break loose over time. Also make sure to check for slop in the bottom alternator bolt hole. I had the alternator bracket wear oblong from wear, causing alternator to move while running...caused all kinds of problems.check the bolt for wear also.Thats all I can think of..Im too tired..good luck..
