mopar pcm
Old May 26, 2007 | 08:21 PM
neonracer1010's Avatar
neonracer1010
Default mopar pcm
is there any way to tell wheather or not the pcm in my car is the performance one, because it was an x-scca car that was raced and has all documents of work done but i dont have them here and i was wondering if there is anyway to tell
i also noticed on the t/b buterfly it says 8529 does that mean its a 52mm
Old May 26, 2007 | 08:56 PM
lblackneon's Avatar
lblackneon
Default RE: mopar pcm
If it's a Mopar pcm, it'll increase the rev limiter to 7400 on the Sohc and 7600 rpm on the Dohc.
Old May 26, 2007 | 08:58 PM
95neonriceeater's Avatar
95neonriceeater
if they didnt mess with it they have a sticker that says "Mopar Performance" on it
Old May 26, 2007 | 10:43 PM
spudsterier's Avatar
spudsterier
ORIGINAL: 95neonriceeater
located on the underside of the pcm
Old May 26, 2007 | 10:46 PM
95neonriceeater
i've seen a few on the top!
is that only for certain years?
Old May 26, 2007 | 10:48 PM
spudsterier
not ure...all the ones ive seen were on the bottom
maybe the sticker comes with the pcm when new and you can put it wherever you want to
Old May 26, 2007 | 10:54 PM
95neonriceeater
i have no idea..hahah
i remember seeing a red r/t on here a while back and it had it on the top
but then i went on eBay and found a 97 with the sticker on the bottom
hmm...
you're probably right spud!
Old May 27, 2007 | 07:24 AM
streetbikr600's Avatar
streetbikr600
is the one from modernperformance.com a real mopar pcm or is it a regular one with electrical mods
Old May 27, 2007 | 07:26 AM
95neonriceeater
it's the real mopar pcm
