GAS TANK
Old May 29, 2007 | 09:00 PM
caa's Avatar
caa
Default GAS TANK
CAN A GAS TANK FROM A 98 NEON FIT A 95NEON
Old May 29, 2007 | 11:42 PM
das2123's Avatar
das2123
Default RE: GAS TANK
Yes you can, but you will need to change the fuel pump as well. The pump modules and fuel lines are a bit different so get that stuff as well.
Old May 30, 2007 | 01:05 AM
spudsterier's Avatar
spudsterier
i took the old metal tank out of my 95 and put in a plastic one from a 97.......like said,
you need the tank, fuel pump, straps the hold the tank in place, and the plastic fuel line that goes from the tank to the metal line (about 6 inches long, kinda shaped like a spiral)
Old May 30, 2007 | 02:39 AM
iwalton63's Avatar
iwalton63
how many gallons is the 95 tank, the ones wiht 4 lug wheels?
Old May 30, 2007 | 02:59 AM
95neonriceeater's Avatar
95neonriceeater
is the metal tank better?
it's metal!
Old May 30, 2007 | 09:54 AM
spudsterier
the metal tanks have a tendancy to rust and corrode......unlike the plastic tanks
as far as i know the plastic tanks are 11.2 gallons....but im not sure about the metal ones
Old May 30, 2007 | 11:15 AM
das2123's Avatar
das2123
ORIGINAL: 95neonriceeater
it's metal!
Easier to change the fuel pump , but it isn't "better" persay and is a bit smaller. ~10 gallons I think.
Old May 30, 2007 | 06:51 PM
KnightRider's Avatar
KnightRider
I think they started making plastic tanks because of static electricity problems at gas stations. I could ,of course, be wrong though...
Old May 30, 2007 | 08:02 PM
spudsterier
i think it had sumthing to do with the corrosion too
