SOHC Manifold
Old May 30, 2007 | 03:36 PM
neon9's Avatar
neon9
Default SOHC Manifold
On this forum I have heard people talk about porting a DOHC intake manifold. Is there a way that you can port a SOHC plastic intake manifold. If it is possible how is it done, and what parts do you need.
Old May 30, 2007 | 04:07 PM
spudsterier's Avatar
spudsterier
Default RE: SOHC Manifold
the plastic manifold isnt extremely thick.....so i would stay away from that...only thing you can really do is gasket match the ends
Old May 30, 2007 | 04:13 PM
das2123's Avatar
das2123
ORIGINAL: spudsterier
Agreed, thats about it unless you have a aluminum SOHC intake manifold.
Old May 30, 2007 | 04:21 PM
spudsterier
ORIGINAL: das2123
yeah....then grind away
Old May 31, 2007 | 02:37 AM
AMM's Avatar
AMM
gasket match the runners, trim the injector humps and u can open up the throttle body hole to a certain extent to fit an o/s throttle body.
