pacesetter header install
Old Jun 6, 2007 | 09:35 PM
zeeds's Avatar
zeeds
Default pacesetter header install
got a pacesetter header today and of course, they put instructions for a 5.2 V8 in with it instead of the neon instructions...anyone know exactly where i need to cut?
Old Jun 6, 2007 | 09:37 PM
95neonriceeater's Avatar
95neonriceeater
Default RE: pacesetter header install
cut?! what do you mean cut?
Old Jun 6, 2007 | 09:49 PM
zeeds's Avatar
zeeds
you have to cut the stock exhaust flange that connects to the stock header off and weld one that comes with the header on in order to make up for the bigger length of the pacesetter
Old Jun 6, 2007 | 10:04 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
DOHC or SOHC? if its DOHC you will have to remove the alternator and brakcet. remover head. and cat.
Cut the cat on the front side if i remember corectly 1 3/8ths of an inch from the weld on the cat and put the clamp on there and rebolt everything back up. then take it to the muffler shop and have them weld it there then take the clamp off
Old Jun 6, 2007 | 10:15 PM
95neonriceeater
oh! well tahts good to know becuase i've never heard anyone having to cut it to fit unless it was mid/long header
Old Jun 6, 2007 | 10:24 PM
DOHCgarrett t3
the pacesetter is a midlegnth at least i think. I just got one and had to cut the cat i dont know if SOHC are diffrent though
Old Jun 7, 2007 | 06:06 AM
95neonriceeater
i'm pretty sure the SOHC just bolts on...
but if i'm wrong please tell me because i'll probably be getting a pacesetter header over the summer
