my tranny is finally back in, but
Old 06-08-2007, 04:22 PM
autoguru77's Avatar
autoguru77
autoguru77 is offline
Default RE: my tranny is finally back in, but
This particular trans does not use a pilot bearing. the input shat is supported by a bearing/bushing in the nose of the trans. If it is popping out of gear it is due to a misalignment of the clutch or synchro/gear damage inside the trans. Did it have this problem before clutch replacement?
Old 06-09-2007, 12:37 AM
racerx55's Avatar
racerx55
racerx55 is offline
how do you misalign a self aligning clutch? (modular)
if its not aligned, any clutch will align itself as soon as you get the pressure off the disc.(releasing the clutch)
a clutch can not be out of alignment or it wont go together in the first place.
Old 06-09-2007, 01:40 AM
neonracer1010's Avatar
neonracer1010
neonracer1010 is offline
what is the problem then, i never had this problem before, and i replaced the tranny and clutch. my old tranny i ruined.
Old 06-09-2007, 12:13 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
i had the same problem with my work car.....so now its an automatic
Old 06-10-2007, 06:15 PM
neonracer1010
spud do u think it could have anything to do with the arms on the tranny case that i got from you that could cause this.
if not i think im gonna drop it again and find someone who has a tranny with the 3.94 ratio.
Old 06-10-2007, 08:55 PM
spudsterier
honestly i couldnt tell ya...from what i was told, that tranny was pulled out so the 3.94 could go in it..
are you talking about the selsctor arms???? i dont think i can really see that being the problem unless the guy bent sumthing putting the stuff together
i have 2-3.94 trannys, but neither of them work right....if i can happen to find out whats wrong with 1 of them then will let you know and you can give it a shot
Old 06-12-2007, 03:13 PM
autoguru77's Avatar
autoguru77
Aha! You replaced the trans with a used one I'm guessing. If it is a used trans then thats probably what's wrong. Check to see that the alignment pins are there. sometimes they come out of the block and stick in the bellhousing of the trans. If you replaced the trans you might be missing one or both of them.
Quick Reply: my tranny is finally back in, but
