Gonna Need Alot Of It
Old Jun 14, 2007 | 02:11 PM
boxerjl2's Avatar
boxerjl2
Default Gonna Need Alot Of It
ok i was looking at Ace and they sell bondo in which im going to need quite a bit of this summer when i get around to fixing up my car but i ran across something called
Bond Glass
anyone ever used it ??
Old Jun 14, 2007 | 03:42 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Default RE: Gonna Need Alot Of It
its just bondo but its the fiberglass resen which you use with fiberglass sheets and its a lot stronger but harder to work with. . . never worked with it though
Old Jun 14, 2007 | 04:32 PM
spudsterier's Avatar
spudsterier
i work with fiberglass all the time
dont get the fiberglass resin, thats a bit more fun to work with then you like and you do need the sheets of fiberglass to go with it.....try to get some short hair fibeerglass jelly....it works just the same as bondo, but its stonger and wont crack as easy....plus you dont need to use the sheets, it has small fiberglass hairs in the jelly
Old Jun 14, 2007 | 04:55 PM
Maui_808's Avatar
Maui_808
I use it all the time in hawaii because vehicles rust so much here, if you got little dings in your car just use bondo, Ive used bondo glass for deep rust holes, I used on the roof of my truck but you end of putting bondo over it for the final job.
Old Jun 14, 2007 | 05:04 PM
boxerjl2's Avatar
boxerjl2
ok so just go with normal bondo?
becuz the people who had the car before me bondod the rain gutters on the roof and the bondo split up out of the paint so im thinking of sanding that down and redoing it better.. but if i use fiber glass how do you get rid of the checkerd look do you bondo over it ??? cuz when ive used fiber glass it has a checkered look as the pattern of the mesh has
Old Jun 14, 2007 | 07:17 PM
spudsterier
if it has the checked look then you used the resin and never put the jelly over top of it.......
the resin with the mat is used more for fixing holes.....but you still need to put bondo or fiberglass jelly over top of it......
Old Jun 14, 2007 | 10:01 PM
boxerjl2's Avatar
boxerjl2
kk wow i learn more everyday
hey spud get ahold of my in PM ASAP about seats
Old Jun 15, 2007 | 02:36 AM
dcmcguy's Avatar
dcmcguy
I made a guage pod out of fiberglass cloth andresin once, it sucked...Its ALOT harder than it looks.
Old Jun 15, 2007 | 05:16 AM
boxerjl2's Avatar
boxerjl2
lol i was thinking about that for the dvd player im installing (maybe)
but i figured i would just mount it somewere
Old Jun 15, 2007 | 10:06 AM
spudsterier
i am in the process of forming a gauge pod for my fuel pressure gauge that will mount in the engine compartment.....it is actually turning out pretty good, hopefully i will be done in a few days since i have to get my motor today, i wont have time to work on the pod....
most important thing about fiberglass is to take your time and not use too much hardener
