Dodge Neon Transmission Problem
Old Jun 16, 2007 | 08:45 AM
devincent_2006's Avatar
devincent_2006
Default Dodge Neon Transmission Problem
Ok, I have a 1995 Dodge Neon 4 door. The transmision goes into reverse and works fine, however it takes about 5 min to warm up and then slides into reverse. The rest of the trani seems to work fine. I have been told many things of what the problem is, like it needs an O ring? I do not have trani education. Can anyone give me some advice as to what might the problem is and where to go for a trani inspection. I live in Fresno, Ca. And I do not have a ton of money to spend. Is there any truthful mechanics out there? Also I am getting very bad gas mailage. It has 108,00 miles and all the fluids are full and changed recently. Is it just wore out or what? It is my wifes car.
Thanks,
Dan
[IMG]local://upfiles/65409/D6D00167287241EC80274EDFE7B85B8E.jpg[/IMG]
Old Jun 16, 2007 | 11:46 AM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Dodge Neon Transmission Problem
Try posting in the Dodge Neon 1st Generation section, there will be more people to help you with your problem. Good luck!
Old Jun 17, 2007 | 02:28 AM
das2123's Avatar
das2123
Is the level OK? Was the reverse band adjusted/tightened when the the filter was changed?
