clutch set question?
Old Jun 18, 2007 | 07:54 PM
neon527's Avatar
neon527
Default clutch set question?
have a 97 SOHC 5 spd swap done,at the auto parts store- guy tells me theirs two different clutch design a "one piece design" where the pressure plate n disc are as one ~n~ the other are interchangeable, my question is does it matter which one i use, if there is a better or worse scenario???? or is is absoultley nessary to use one or the other, the way i went was by the 8th VIN, n came out "D" calling for the one piece design...... :P
IF anyone has a soultion/answer it would be much appreciated thanks!!
Old Jun 18, 2007 | 09:29 PM
Leonheart17240's Avatar
Leonheart17240
Default RE: clutch set question?
what year did the tranny come out of? and it would me a modular or nonmodular clutch... i did the swap with a 95 sohc tranny and needed a nonmodular clutch
Old Jun 19, 2007 | 12:37 AM
neon527's Avatar
neon527
it was also a 97 neon, wat do u mean a modular or nonmoduar??, srry to sound dumb but im sort of new to this stuff..
Old Jun 19, 2007 | 01:35 AM
Leonheart17240
im not 100% on it ether but in a modular the flywheel comes a part of the clutch when you buy the kit...
Old Jun 19, 2007 | 10:32 AM
spudsterier's Avatar
spudsterier
ORIGINAL: Leonheart17240
neither one of the clutches have the flywheel attached.....
modular is the 1 piece and non-modular is the one that has the separate components......
modulars came on u.s. built neon.......non-modular were on mexico built neons....
you will have to get the clutch that will match your flywheel since the flywheels are different between the 2
Old Jun 19, 2007 | 11:43 AM
das2123's Avatar
das2123
If your VIN# starts with a 1, it was made in the US and has a modular clutch.
Old Jun 19, 2007 | 10:24 PM
neon_leon's Avatar
neon_leon
use the flywheel from the automatic and a modular will match up Ive done it with a couple neon 5 speed swaps.
