Help quick im stumped!!
Old Jun 20, 2007 | 05:56 PM
HabitatHxC's Avatar
HabitatHxC
Default Help quick im stumped!!
Ok this is my second neon and its buggin me trying to fix it. Well First the things i have replaced or changed.
Cam sensor
Spark plugs and wires
Blocked off EGR
I pulled the throttlebody off and cleaned it up real nice.
Ok So Here is the problem now.
It sucks funny through the IAC motor hole, kinda like its choking.
It sometimes wont want to idle i give it gas and it goes for a bit.
Sometimes when it doesnt want toidle and im driving (intown)i have to give it Full throttle to get it to move. And it MOVES when i do.
I havent found a pattern to the Missfire/bad idle.
I have too many options to go out and fix them all. So anyone have any ideas of what it could be?
Crank sensor? IAC? TPS? Clogged cat? Fuel pump/filter?
If anyone has ANY idea help me out asap! i need to get her in working condition for the morning drive to work!
Old Jun 20, 2007 | 06:09 PM
mathias's Avatar
mathias
Default RE: Help quick im stumped!!
Just a thought, but try disconnecting your vacuum lines. Make sure the vacuum line from the canister to the fuel tank is unhooked too (It's going to be near the passenger side fender well across from your alternator.). Plug the vacuum inlet on the throttle body with a buddy's finger and start her up. If it idles smoother then, the charcoal canister could be clogged and causing some fuel starvation issues at lower revs.
Could be a lot of stuff really, but that just came to mind.
Old Jun 21, 2007 | 12:28 AM
spudsterier's Avatar
spudsterier
possibly a map sensor.....
what about a check engine light???
Old Jun 21, 2007 | 12:36 AM
NEONRT98's Avatar
NEONRT98
IMO, I would start with the IAC, if that doesnt do it, try the TPS
Old Jun 21, 2007 | 12:38 AM
HabitatHxC's Avatar
HabitatHxC
TCC selinoid, and bad O2. the only codes, We swapped out a different IAC sucked/choked air differently, but still wouldnt work right, In the throttle body it sounded like if you were to letmore air go through the IAC port it would work better but cant get it to work. And after i got it all changed out and gave up for the day it wouldnt hold an idle at all. So i made a duct tape spacer for now and it holds at about 1000rmp. drives fine .
Old Jun 21, 2007 | 04:20 AM
loud99R/T's Avatar
loud99R/T
if the cat were to be clogged would i hear it? becuase i am getting a funny exhaust noise like air is being forced through something.
Old Jun 21, 2007 | 10:38 AM
spudsterier
might just be leaking out of the donut gasket......or 1 or more of the exhaust manifold bolts are broken/missing
