bearing oil clearance????
Old Jun 21, 2007 | 01:02 AM
spudsterier's Avatar
spudsterier
Default bearing oil clearance????
so i was checking the oil clearance in my main bearing today with a plast-gage when i was attempting to install the crank in my block....
well im not to good with this kinda technical stuff so,
the haynes manual says the allowable clearance is 0.008 - 0.0024
well the plasti-gage shows my clearance is about .025 - .038
so
is this o.k. or do i need to get different bearings?????
Old Jun 21, 2007 | 01:17 AM
Leonheart17240's Avatar
Leonheart17240
Default RE: bearing oil clearance????
i have know clue, but if the hole is bigger= more oil and i would think that would be a good think... buti wouldnt go on my advice.
Old Jun 21, 2007 | 10:30 AM
spudsterier
if its bigger then it also leaves you a better chance of spinning a bearing
i just dont know if i need thicker bearings or not
Old Jun 21, 2007 | 04:29 PM
spudsterier
nevermind...i figured it out and im good to go...
the gauge has MM and INCHES.....i was looking at MM when i needed to be looking at INCHES[sm=bangbang.gif]
Old Jun 21, 2007 | 04:36 PM
marsh712's Avatar
marsh712
haha
Old Jun 21, 2007 | 06:03 PM
racerx55's Avatar
racerx55
.003" on evrything is a good place to be with a high volume oil pump.
Old Jun 21, 2007 | 07:46 PM
spudsterier
yeah well when i read the gauge it was at .035 - .038....well that was in MM
so it is actually .001 - .0015 INCHES
and if the allowable clearance is .008 - .0024 then i should be good to go..
and, i dont know if the oil pump would be a high volume or not......i just ordered it from modern performance since my stock oil pump was pretty clogged up with metal shavings from my old bearings[&:]
Old Jun 21, 2007 | 09:23 PM
Leonheart17240
just wondering how much did the oil pump run ya...
Old Jun 22, 2007 | 10:21 AM
spudsterier
$90 from MPX
Old Jun 23, 2007 | 11:04 PM
racerx55's Avatar
racerx55
1 thousandths is really tight, wow.
my motor is .003 on evrything, but its built for racing so it makes it rattly when its cold.
