how do i get the engine code?
Old Jun 21, 2007 | 05:17 PM
mulletman11's Avatar
mulletman11
Default how do i get the engine code?
my check engine light is on, i understand how to read the code, but i can not get it to blink. help?
Old Jun 21, 2007 | 05:38 PM
das2123's Avatar
das2123
Default RE: how do i get the engine code?
https://dodgeforum.com/m_63384/tm.htm
Old Jun 21, 2007 | 05:52 PM
mulletman11
problem....
i did that, no flashes?!?!?
Old Jun 21, 2007 | 06:05 PM
das2123's Avatar
das2123
You should at least get a code 55. If not, you are doing something wrong.
Old Jun 21, 2007 | 06:11 PM
mulletman11
yea, i just dont know what
Old Jun 21, 2007 | 06:32 PM
das2123's Avatar
das2123
You are turning the key to the ACC-ON right, and not actually turning on the car??
Old Jun 21, 2007 | 06:43 PM
mulletman11
im turningthe keyback to turn the radio on, then off, then on. and none of my cluster lights come on.
Old Jun 21, 2007 | 07:05 PM
das2123's Avatar
das2123
Not backwards....forward like you are going to start the car but not all the way.
Old Jun 21, 2007 | 07:20 PM
mulletman11
thats probably why its not working. but i didnt know that it can go forward and work the radio. im at work, ima go try it right noiw.
thanx.
Old Jun 21, 2007 | 07:56 PM
mulletman11
code 21 and 12
so, i disconnect and reconnect my negative battery terminal, for the 12, the 21? o2 sensor? the light sometimes comes off and on, but it reads 21, wat do i do to fix??
