Map missing link???
Old Jun 24, 2007 | 02:28 AM
turbodneonracer96's Avatar
turbodneonracer96
Default Map missing link???
Where do i go about finding one of these. And is there an easier way of trying to fool the computer to where it doesnt see boost. Well i need to do something im not running my car with boost and a CEL.
Old Jun 24, 2007 | 02:29 AM
turbodneonracer96
Default RE: Map missing link???
Oh i have a Mopar Pcm if it matters.
Old Jun 24, 2007 | 04:45 AM
loud99R/T's Avatar
loud99R/T
you cant run a mopar pcm with boost it advances the timing too much. just swap back to your stock pcm and you should be good to go. im sure someone else will chime in
Old Jun 24, 2007 | 03:24 PM
turbodneonracer96
I thought you could run a mopar performance pcm with boost. What the hell.
Old Jun 24, 2007 | 07:08 PM
spudsterier's Avatar
spudsterier
the mopar pcm advances the timing too much for the turbo and you can have a pre-detonation problem...
the turbo works the best with the timing retarded a bit...but will work just fine with the stock timing.....
if you dont wanna have to replace your motor soon, then get rid of the mopar pcm
there really isnt an easier way to hide the boost other then a map clamp and the map clamp isalmost the most important thingwith a turbo 1st gen neon......
dont get one from ebay....they are junk.....it costs a bit more, but you can order one directly from hahnracecraft.com for $100
Old Jun 24, 2007 | 09:28 PM
turbodneonracer96
thanks Spud. ill go and get a factory pcm on monday. Then i should be fine other than a half a tooth advanced on timing. But do you really think that would make a motor predetonate. Hell for all i know it could only be retarded. When i did my timing and followed the Hanes manual, they said three notches BDC and then a half notch well when i set the timing the damn half notch didnt move but a pubic hair from where it started so i really think im retarded a half notch.
Old Jun 25, 2007 | 01:06 AM
spudsterier
if its before t.d.c. then its retarded......
if it ended up being advanced, it wont ruin the motor unless you started running alot of boost....then you might have to worry
Old Jun 25, 2007 | 02:15 AM
turbodneonracer96
Well the most boost i was gonna go was 10 psi for now. But my motor will handle 17psi.
Old Jun 25, 2007 | 10:06 AM
spudsterier
whats the motor got done to it??????
Old Jun 25, 2007 | 07:13 PM
turbodneonracer96
Low compression valves and a dohc on a sohc block. Injectors,fmu,msd 6a,. My buddy brian has seen a a guy run 17 psi with the same setup as me and he is still going today and the motor was built 3 years ago. Im not gonna run 17 psi all the time my max is gonna be 10 psi all the time. And the motor should be fine. Im not worried.
