Stock SOHC 132 Hp
Old Jun 25, 2007 | 05:19 AM
boxerjl2's Avatar
boxerjl2
Default Stock SOHC 132 Hp
but how much is that to the wheels
im guessing the 132 is to the crankshaft so how much of it is to the actual tires i think you guys call it Whp
just curious
Old Jun 25, 2007 | 06:09 AM
estneon's Avatar
estneon
Default RE: Stock SOHC 132 Hp
80-100whp still beats civics and we're the under dogs lol
Old Jun 25, 2007 | 10:09 AM
spudsterier's Avatar
spudsterier
should be in the 115 to 120 range
Old Jun 25, 2007 | 01:49 PM
neoncrazy101's Avatar
neoncrazy101
i love in that sport compact thing when they call the SOHC the underachiever since to them it makes 110hp at the wheels...what does that make the Civic, Corolla, Escort's motors?
Old Jun 25, 2007 | 02:08 PM
das2123's Avatar
das2123
Around 110 from the only stock SOHC dyno that I have seen.
Old Jun 25, 2007 | 04:02 PM
spudsterier
i was just estimating
Old Jun 25, 2007 | 08:46 PM
estneon's Avatar
estneon
you have to add lbs to the factor if you have five subs and a few amps and all this for looks stuff you will fell like 80whp if not less
Old Jun 25, 2007 | 11:48 PM
das2123's Avatar
das2123
It's been said that you can lose 0.1 of a second for every 100 pounds you shed.
Old Jun 26, 2007 | 06:41 PM
mulletman11's Avatar
mulletman11
ok so beyond cleaning out your trunk and taking out sound padding between your doors, how do you lose pounds?
Old Jun 26, 2007 | 06:56 PM
das2123's Avatar
das2123
ORIGINAL: mulletman11
Get rid of anything you don't "need". You can remove the P/S and A/C, glove box, rear seat, passenger side seat, lighten your doors by cutting out some of the material, remove spare tire, use a smaller battery, replace fenders, hood and turnk with carbon fiber or fiberglass, replace glass with Lexan and so on...
