DOHC cylinder head
You do know that milage isnt really a factor in how good that head is?. I've seen cracked aluminum heads at 10,000 miles let alone 70,000 miles i'd really be more concerned about price than Mileage. Besides Mileage reflects more on crank rods and pistons than the actual head casting itself. Single overhead cam heads are better anyways.... lighter more reliable andminimal power loss and less crank drag on pulling an extra cam shaft.People seem to forget they underated this motor as not to take away from the DOHC's introduction. The DOHC makes more seat of the pants power due to better factory exhaust andbetter computer settings. the factory Dyno of both Engines prior to production was 144hp for the SOHC and 150hp for the DOHC so to me it doesnt pay to have a less reliable engine that will cost more to build. Also don't forget that the DOHC engine had higher compression which has nothing to do with the "EXTRA CAM" hence the 6hp gain over the SOHC, its because of higher compression pistons. Buy some high compressionKeith Black Hyperutectic Pistons and a cheap SOHC Head
Forget what I said if your motor was allready a DOHC, then I can see why you want it back to normal.
Have a nice day!
Have a nice day!
Where abouts are you Civic Eater?
There are two JunkYards South West of Atlanta with a few heads.
I just picked up one 3 weeks ago for $100 - sent it straight to the Machine shop - found a crack - took it back to the Junk Yard and they gave me another one - the 2nd one is Golden got back from the Machine Shop last week and started installing it last night trying to get ready for this weekends race in Savannah
ORIGINAL: Slashwannabe
ORIGINAL: das2123
Where is this information coming from? I would like to know.
to "de-tune it" they put restrictive exhaust and mild PCM tuning
Trending Topics
ORIGINAL: spudsterier
dohc's still have better top-end power
And from expirence I can tell you from expirence that going 115the Engine is at 4100RPM's,by the time the DOHC's aggressive cams come into play around 5800the rev limiter is pushing you back down to 118. Even so if you want more top end out of your SOHC swap a stock95 cam into your 96 and later SOHC car and you will gain the top end needed to delete the DOHC's advantage.
Doing simple mods to the SOHC are easier andpay off morein power than just swapping a whole newDOHC engineinto your car.
das2123
Date 6/27/2007 2:56:33 PM
[blockquote][/blockquote]
So are you saying if I were to put a DOHC PCM and DOHC muffler on my stock SOHC engine, my numbers would be comparable to a DOHC engine?
My '98SOHC without a DOHC PCMwill smoke aDOHC equipedcar up to 75mph then after 75 it equals out and is a side by side race, and if I had a cam from a 95 SOHC in my car it wouldnt be an equal race it would be a killing.
Many people don't chance it but I do because I had to prove a point to a DOHC car once, off the line I put my car in neutral and put it up to 5200RPM and slamed it into drive once the light turned green and I just about melted that DOHC car off the line and smookedhim very good up until about 75 where his 5 speeds gearing was getting a chance to catch up and I blame that on my automatics loooong 3rd gear not the SOHC engine, automatic DOHC's are slower given the same opertunity. I do not recomend doingneutral drops but one thing it did prove is if you got the ***** to risk your SOHC'stranny you can wipe the smile off the guys face at Auto Zone who laughs at your SOHC and turn that into respect.
Both engines have similar potential for power but due to design from factory the DOHC actually needs machine shop work done to it (such as milling the head) to have similar potential that the SOHC can gain by just byswapping stockparts.
