R/T or MP ???????
Old Jul 9, 2007 | 03:00 AM
racerx55's Avatar
racerx55
Default R/T or MP ???????
Ive seen on forumsand heard from different people that the R/T PCM is the same thing as the MP PCM.
yes or no?
someone clarify this [&:]
Old Jul 9, 2007 | 04:47 AM
95neonriceeater's Avatar
95neonriceeater
Default RE: R/T or MP ???????
i'm pretty sure the r/t pcm doesn't add hp to the DOHC and not as much to the SOHC
and the r/t pcm has the 130 governer when the mp doesnt have one
Old Jul 9, 2007 | 05:06 AM
racerx55's Avatar
racerx55
i dont need to go that fast, just a few extra HP, i have a 98 r/t computer in it now, which seemed to be an improvement over the 96 ATX computer..... maybe ill just go for the AFX race
Old Jul 9, 2007 | 07:18 AM
spudsterier's Avatar
spudsterier
as far as i know the r/t pcm is better then the regular dohc pcm.....but the mp is even better then the r/t pcm
Old Jul 9, 2007 | 09:02 AM
NYG's Avatar
NYG
ORIGINAL: racerx55
yes or no?
I have NOT dyno my car - but the MP seems to be better tuned to my driving needs (racing needs)- It seems to havebetter power thru the band better then the R/T PCM
Also I can not get my MP to pass Emissions test - so I swap back and forth between the R/T PCM and the MP PCM
Old Jul 10, 2007 | 04:05 AM
racerx55's Avatar
racerx55
i need some more midrange torque, still cant get it out of this motor [&:]
Old Jul 10, 2007 | 04:19 AM
95neonriceeater
oh with the mopar pcm you'll feel it
Old Jul 10, 2007 | 06:05 AM
racerx55's Avatar
racerx55
i still need more
i need to build a 2.6L stroker or somethin rediculous
Old Jul 10, 2007 | 08:46 AM
das2123's Avatar
das2123
ORIGINAL: racerx55
Unless you are going to use a header with it (which you probably won't), don't waste your money. The AF/x is tuned for a header.
Old Jul 11, 2007 | 10:33 AM
NYG's Avatar
NYG
ORIGINAL: das2123
Thats good to know - I am trying to figure out how another Neon beat me a couple of weeks ago when both of our cars are factory stock - but I did notice the AF/x PCM - need to check for a header on the other Neon.
