1996 Neon Sport Battery Light???
Old Jul 19, 2007 | 03:39 PM
justgiver's Avatar
justgiver
Default 1996 Neon Sport Battery Light???
Hi. I have a 1996 dodge neon sport with around 163,000 kms on it. The car had some lighting issues like all the lights being buggered up, but I got that resolved. It has been sitting for 2 years and I finally pulled it out again. I changed plugs, filter, oil, (and all the other routine maintanence things). The battery light is on and it won't go out. I checked the battery with a volt meter and it read 4.4 with the car off. Started and running it reads 14.4. Well I'm pretty sure the battery was toast (low water and being dead through 2 very cold winters) I bought a new one thinking that could be it. Well it still stays on. There was a broken fog lamp (I think) bulb hanging down so I took that out. There are some connectors at the front off the car not hooked up to anything, but I don't think that's it.
What do you think is causing this? It seems like either there is a slow draw on the battery or else it's not charging at all. Why the 14.4 when it's running??
Old Jul 19, 2007 | 05:08 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: 1996 Neon Sport Battery Light???
Check the trunk light by going through the back seat when the trunk is closed. I had this happen on mine and replaced the battery but then the same thing happend again, so I thought it was the alternator but was at about 14 volts when on. So, I did what I just said and found the trunk light was not turning off, just un pluged it and fixed the problem.
