Wire diagram
Old Jul 20, 2007 | 10:06 PM
ryanpernack's Avatar
ryanpernack
Default RE: Wire diagram
[/quote]So they used to turn on after you turned the car off???
That was a problem you should have fixed back then. Sounds like it's working correctly now.
[/quote]
no i don't remember the fans ever coming on. the overheating when i turned off the car just started on monday.
Old Jul 20, 2007 | 10:13 PM
Aerorat's Avatar
Aerorat
the fans will run after thr car has been cut off for a few minutes
Old Jul 21, 2007 | 12:52 PM
ryanpernack
Mine don't, but they will run when the car is on. where could the problem be there. i know that the fuse for the fan and rad is still good i tested it. where could the problem lay?
Old Jul 21, 2007 | 05:43 PM
ryleynoyes's Avatar
ryleynoyes
if you have a haynes manual, go to 12-27, and they have the wiring diagram
