door panels part 2
Old Jul 24, 2007 | 04:46 PM
boxerjl2's Avatar
boxerjl2
Default RE: door panels part 2
why spend 8 bucks on a kit when im sure you have a fork laying around
Old Jul 25, 2007 | 01:03 AM
luckycharms's Avatar
luckycharms
can i see the clip when i push the panel in or is it just like trial and error and im gunna try the fork and if that does work just get the kid
Old Jul 25, 2007 | 01:15 AM
kris95neonspt's Avatar
kris95neonspt
Its kinda hard to see the clip if the fork don't work.I read the post boxer provided see if the wash cloth will work thats in the tread.I never tried that on it might be easier. But remmber put something down to keep that clip from flying out cause it will usally get lost if it does or it can hit you also.
Old Jul 25, 2007 | 02:42 AM
boxerjl2's Avatar
boxerjl2
the clip was easy to get to just push in the door panel and you should see it and if you dont then turn thewindow crankand eventually youll see it.. i did it right after reading that post that i gave the link to quit simple my problem was not seeing it but i kept turning it and finally found it
Old Jul 25, 2007 | 03:57 AM
Dr_KY's Avatar
Dr_KY
Here man just try it this way and nobody gets hurt.
http://www.youtube.com/watch?v=2LX_n_z3LrM
I wouldn't go poking around with a fork as it has points and maydig into your interior. If you pay attenion to the video clip you will be able to tell where and in what position the clip is installed so no need to shove the door card in so you can try and find it
Removing the door card is not a big deal or a tough job so don't make it one.
Old Jul 25, 2007 | 12:38 PM
luckycharms
after im all done and ready to put it back together how do i know were to replace the clip
Old Jul 25, 2007 | 12:41 PM
boxerjl2's Avatar
boxerjl2
i just put it back on the **** and popped the **** back into its place
Old Jul 25, 2007 | 12:58 PM
luckycharms
thanks, yeah i was trying for like an hour yesterday and couldnt fiqqure it out
