Idle speed 98 neon
Old Jul 24, 2007 | 10:26 PM
benny1426's Avatar
benny1426
Default Idle speed 98 neon
Did anyone know what the idle speed is suppose to be in a 98 neon SHOC? I change the whole cluster today with a tach (I don't have one before) and it idle at a little bit more than 1000. Just want to know is it normal. Also, I put a new cluster on with a lot more miles on it, Can I change it somehow or I have to live with it. Thanks in advance.
Old Jul 24, 2007 | 10:39 PM
Leonheart17240's Avatar
Leonheart17240
Default RE: Idle speed 98 neon
sounds nom for a stock tach... but i have found that stock tachs can me off by a few rpm... when i put my faze in i idle at 900 where before it was at 1100.... same with other aftermarket tachs... and other cars
Old Jul 24, 2007 | 11:03 PM
Slashwannabe's Avatar
Slashwannabe
My engine idles at 820rpm so says my in dash tach and my laptop conencted to the OBD-2 port.
Old Jul 24, 2007 | 11:56 PM
neoncrazy101's Avatar
neoncrazy101
in my '95's it idles at 900 and in my '97 it idles at 800 and is rough. so much for the "idles to rough with the 4hp cam in the 95's" i think its because of my o2 sensor is bad though lol.
Old Jul 25, 2007 | 07:16 AM
spudsterier's Avatar
spudsterier
usually about 900 is normal
Old Jul 25, 2007 | 07:40 AM
Dr_KY's Avatar
Dr_KY
What software are you using on that laptop to get those readings?
Old Jul 25, 2007 | 07:56 AM
spudsterier
the proscan program i have works pretty good
Old Jul 25, 2007 | 08:31 AM
das2123's Avatar
das2123
ORIGINAL: benny1426
You can swap odometers in to keep your milage correct and NO it isn't against the law. It's pretty easy, but you will need a T15 and T9 torx bit.
