belt replacement!!!!!!!!
Old Jul 31, 2007 | 12:14 PM
jt46324's Avatar
jt46324
Default belt replacement!!!!!!!!
i need to know how many belts the 99' neon sohc has minus the timing belt. I am replacing them all this weekend and have found quite a few online at autozone.com,
What ones do i need. Here are thwe links and whats the differnece.
http://www.autozone.com/R,APP151086/...ductDetail.htm
http://www.autozone.com/R,APP156433/...ductDetail.htm
can someone link me in the right direction.
thanx
Old Jul 31, 2007 | 01:13 PM
das2123's Avatar
das2123
Default RE: belt replacement!!!!!!!!
Besides the timing belt, you have the alternator belt (goes from the alternator to the crank pulley) and you have the power steering/AC belt (which goes around both and then to the crank pulley).
Old Jul 31, 2007 | 01:15 PM
spudsterier's Avatar
spudsterier
from what i can tell both those belts are basically the same....just a different style
you will need 1 v-belt for the powersteering/ air conditioning
and 1 serpintine style belt for the alternator
Old Jul 31, 2007 | 05:34 PM
Slashwannabe's Avatar
Slashwannabe
I got a question!,
How long of a belt would I need to bypass theAC pump? my clutch went down and is screaching and annoying the fk outa me so Iwant to bypass it.
