egr block off
Old Aug 9, 2007 | 12:06 AM
neonracer1010's Avatar
neonracer1010
Default egr block off
any one have any ideas on how to make an egr block off
SPUD
Old Aug 9, 2007 | 01:03 AM
protivakid's Avatar
protivakid
Default RE: egr block off
Will this really add much more power?
Old Aug 9, 2007 | 01:04 AM
mmench's Avatar
mmench
get some 1/8 inch thick steel or some size like that. use a plasma cutter to make the rite shapes to cover the egr portsand bolt the plates on. im gona make a block off kit for my car... wont be for a few weeks but ill post it when i do it
Old Aug 9, 2007 | 01:06 AM
neonracer1010
can it be roughly the same shape, and instead of gaskets can i use black rtv
Old Aug 9, 2007 | 07:40 AM
HabitatHxC's Avatar
HabitatHxC
I used two sheets of aluminum... from pop cans, for the intake. and a penny for the egr spaceship thingy.
Old Aug 9, 2007 | 09:23 AM
das2123's Avatar
das2123
ORIGINAL: protivakid
Won't add any HP at all
ORIGINAL: mmench
All that isn't necessary. You can use a coke can and just cut it to the shape of the gasket and slide it in between.
You will get a Code 32 if you don't have an aftermarket PCM.
Old Aug 9, 2007 | 10:44 AM
spudsterier's Avatar
spudsterier
i used some 1/16" aluminum that was about 2 inches wide.....traced the pattern on it from the gaskets....then used tin snips to cut it out....after that i used the dremel to smooth out the edges...
i could make you the plates if you want...only takes about 5 minuites
Old Aug 9, 2007 | 03:32 PM
Slashwannabe's Avatar
Slashwannabe
ORIGINAL: das2123
das this is probably one of the only things I disagree with you on, but maybe theres something I'm missing, The EGR heats up the Intake charge with hot exhaust gas, generally cars gain Horse Power when the intake charge is cooler hence what Nitrous does is cool the fuel and air charge thus gaining power. Now I'm not trying to compare nitrous to an egr block off, I just think the same principal is there with cooler intake charge = more power. I would think the egr block off does more for HP gain then taking the weather stripping off the cowl as some have stated helps.
Old Aug 9, 2007 | 03:53 PM
das2123's Avatar
das2123
Your idea sounds correct in theory. So get the car dyno'd and measure the engine temp with a functional EGR valve and then block it off and do the same thing and post results.
Old Aug 9, 2007 | 10:43 PM
neonracer1010
aight spud, ill take u up on making them for me. and i got my vacum leak fixed, the one hose that goes into the spaceship thingy had a big slice in it
