SHOC or DHOC for cold air intake
Old Aug 15, 2007 | 04:33 PM
joecool6101's Avatar
joecool6101
Default SHOC or DHOC for cold air intake
i have no idea what either of those are. But my friend recommended i purchase a cold air intake to give me more horse power and better fuel milage.
Now i dont want to go spend a lot of money on this then find out i got the less ideal type. So what should i get a SHOC or a DHOC ?
Thanks,
~Joecool6101
Old Aug 15, 2007 | 04:56 PM
spudsterier's Avatar
spudsterier
Default RE: SHOC or DHOC for cold air intake
it is a SOHC or DOHC....
if your getting a cold air intake then most of the time it really doesnt matter what engine you get it for....but it depends on what you have
Old Aug 15, 2007 | 05:07 PM
joecool6101
so SHOC will work with my 96 neon?
spudsterier
if you have a SOHC motor....but either way, it should work
Old Aug 15, 2007 | 05:21 PM
joecool6101
how do i tell what type i have
Old Aug 15, 2007 | 10:06 PM
spudsterier
what year is your car????
a dohc will have a silverish aluminum intake manifold
a sohc will have a black aluminum or plastic intake manifold
Old Aug 15, 2007 | 10:07 PM
winsettz's Avatar
winsettz
CAI for the neon isn't affected by engine type (If you've got an ATX and an Iceman, you have to cut the tube)
In addition to intake manifold, your snorkel should say SOHC or DOHC on it. You may check your valve cover as well, or match it up based on the VIN. DOHC's usually have the bulge hood as well.
Old Aug 15, 2007 | 10:10 PM
spudsterier
ORIGINAL: winsettz
the 95's do not have the snorkel on it that say sohc or dohc....
none of the years will say on the valve cover....
alot of 95 sohc had a sport bulge hood
Old Aug 15, 2007 | 10:46 PM
protivakid's Avatar
protivakid
The Iceman intake is what you are looking for.
Old Aug 17, 2007 | 08:59 AM
das2123's Avatar
das2123
ORIGINAL: joecool6101
Check the 8th digit of your vin#. If it's a Y, then it's a DOHC. If it's a C, then it's a SOHC.
