bad starter???
Old Aug 19, 2007 | 12:32 AM
pssssst's Avatar
pssssst
Default bad starter???
my other thread referring to starting problems says that when my engine got wet while it was running it shut off and wont start anymore... i was spraying in the front near the starter when it happened.... can the car still turn over with a bad starter??? its making the nanananana sound and just wont fire up.. any help is appreciated! thanks!
Old Aug 19, 2007 | 12:43 AM
SirShroomy's Avatar
SirShroomy
Default RE: bad starter???
When you say you sparying near the starter, does this mean you had your hood up? Do you think you maybe got water into the air intake duct, and suck water into the engine?
Old Aug 19, 2007 | 01:57 AM
pssssst's Avatar
pssssst
my duct is gone... i have a cold air intake so that couldnt have happened i was basically just giving the motor a quick rinse to clean it up a bit which ive done plenty of times before and this time it just shut everything down [:@]
Old Aug 19, 2007 | 09:49 AM
dcmcguy's Avatar
dcmcguy
good one...
Old Aug 19, 2007 | 12:08 PM
pssssst's Avatar
pssssst
what do u mean good one?
Old Aug 21, 2007 | 06:54 PM
dcmcguy's Avatar
dcmcguy
nice job....ive hosed my neon motor many times and its never acted up for me, sooo... idk
Old Aug 22, 2007 | 12:44 AM
12 volt's Avatar
12 volt
first thing i would do is make shur that the connections on you battery are clean enough that they shine like a new nickle. Then when you shur that the power supply is 100% flip open the fuse box and make sure that no water is inside. Find your stater relay and ensure that it is good before you start ruleing out the starter.
Old Aug 22, 2007 | 12:59 AM
12 volt's Avatar
12 volt
i forgot to ask if you check your sprak plug holes for water.
does the nanana sound mean the engineis turing?
if the engine died when the car was running then itcoulden'tbe the starter. right?
Old Aug 22, 2007 | 01:08 AM
neonracer1010's Avatar
neonracer1010
the CAI mite have sucked water up
