tapping/slapping noise
Old Aug 23, 2007 | 11:41 PM
stoopidpyro's Avatar
stoopidpyro
Default tapping/slapping noise
i recently bought a '97 2.0dohc neon highline.. but it has an issue.. when the engine is running, it makes a tapping sound.. pretty close to the level of someone clapping their hands (so not too loud). my dad thinks its the lash adjusters, but we took each one out and 'tested' them as the manual said.. although it didnt specify how-to exactly, (we just squeezed them to see if oil would come out) and all seemed in shape. we checked the timing, and pumps, theyre all in shape and correct.. we think the noise is at the top of the engine, we did a compression test, each cylinder passed, and all rocker arms are in what seems to be good shape. so any ideas? i appreciate any and all help =]
Old Aug 23, 2007 | 11:46 PM
jdm0830's Avatar
jdm0830
Default RE: tapping/slapping noise
rod knock.
Old Aug 23, 2007 | 11:48 PM
stoopidpyro
that would be like a loose piston rod right?
Old Aug 23, 2007 | 11:50 PM
neoncrazy101's Avatar
neoncrazy101
could just be the valves. the valves on startup chatter (sometimes loud sometimes not) since the oil is up there yet. and it could also do it due to low oil.
Old Aug 23, 2007 | 11:54 PM
stoopidpyro
the sound stays the entire time it's running.. but u may be right about the oil.. the oil light does turn on, but someone insisted thats normal in some neons *doh*
Old Aug 24, 2007 | 03:47 AM
reaperof_evil's Avatar
reaperof_evil
Yeah I have the same noise mine's a 97 Plymouth Peon Sohc I run sythetic oil with Lucas and still taps take it to a garage and get the valves adjusted that should fix it.
Old Aug 24, 2007 | 04:06 AM
racerx55's Avatar
racerx55
if its not very loud its probly the normal piston slap noise.
nothing to worry about if thats what your hearing unless its hammerin like this one.
http://youtube.com/watch?v=dv34zn59x-8
that is a rod knock ..
Old Aug 24, 2007 | 04:40 AM
purecty's Avatar
purecty
i have a99 neon with the noise but it gets quiet after warming up, is that normal? it gets a pretty loud tapping sound but it does stop.
Old Aug 24, 2007 | 08:02 AM
spudsterier's Avatar
spudsterier
ORIGINAL: purecty
yeah its normal...
