Radiator fans not working
Old Aug 28, 2007 | 06:25 PM
bruno86's Avatar
bruno86
Default Radiator fans not working
hey i have a 99 neon RT with about 145k. just put on the 3.0 intake and under 2 weeks later my car started overheating. After taking a look at the car i noticed that the radiator fans were not working. I tried putting on the a/c to get them to fire up and all that but still nothing. No fuses are blown and the connections to the fans are fine. I ended up bringing it to a little local auto shop to try to figure this out and they told that they were willing to bet that it was the PCM. I have an afx race PCM so i'm really hoping that I wont need to be losing all that cash invested in it. any ideas on other problems it could be or possibly a way to have the PCM reflashed without losing the mods? i dont think howell has a warranty on electrical parts but does anyone know for sure?
Old Aug 28, 2007 | 10:27 PM
spudsterier's Avatar
spudsterier
Default RE: Radiator fans not working
at 145,000 miles maybe your fan relay just went out....
Old Aug 28, 2007 | 11:08 PM
bruno86's Avatar
bruno86
the hanes manual doesnt go into much detail about relays besides saying that it should be taken to a shop to have it checked out....any way i can check it out myself? where would the relay be located?
Old Aug 29, 2007 | 04:50 AM
tattoojack's Avatar
tattoojack
the relays are in a box by the battery unser the hood. on the inside cover it says which one is for fan. pull out and go to autozone, etc. and they will have it. at most $9
Old Aug 29, 2007 | 08:11 AM
spudsterier
the fan relay is located on the frame rail underneath the battery tray......it is easiest to locate from under the car....
a new one from autozone will run you $43.99 so your best bet is to go to a junk yard
Old Aug 29, 2007 | 08:14 AM
tattoojack's Avatar
tattoojack
they are seriously that much? damn! it seems like every car i have owned, this relay was bad and it was never more than $9. what is the deal with the neon parts?
Old Aug 29, 2007 | 08:17 AM
spudsterier
http://www.autozone.com/N,15701337//...eResultSet.htm
Old Aug 29, 2007 | 08:20 AM
tattoojack's Avatar
tattoojack
hmmm. that link says 8.99 and 13.99. but i also have a 96sohc mtx.
Old Aug 29, 2007 | 08:27 AM
spudsterier
oops....wrong year....his car is a 98 so this is the link i wanted
http://www.autozone.com/N,15701337/s...eResultSet.htm
Old Aug 29, 2007 | 09:38 AM
das2123's Avatar
das2123
ORIGINAL: bruno86
That is just freaking retarded. Shops always seem to jump to the conclusion that the PCM is bad. If they told you this, I would go to a different shop from now on. Or ask them what they are willing to bet and then pop in the new fuse in front of them.
