Question about sensors
Old Sep 9, 2007 | 07:40 PM
RiceBoy_88's Avatar
RiceBoy_88
Default Question about sensors
What happens when your idle air control sensor goes bad?
What happens when your throttle position sensor goes bad?
Old Sep 9, 2007 | 10:46 PM
RiceBoy_88's Avatar
RiceBoy_88
Default RE: Question about sensors
Bump
Old Sep 10, 2007 | 08:56 AM
Slashwannabe's Avatar
Slashwannabe
I sure would like to know myself I'm a noob at this electronic sensor stuff.
Old Sep 10, 2007 | 12:12 PM
das2123's Avatar
das2123
You usually get a bad idle or rough running motor.
Old Sep 10, 2007 | 01:01 PM
RiceBoy_88's Avatar
RiceBoy_88
I have a bad miss when i push on the gas easy. and then sometimes when iam sittin somewhere talkin or whatever it will rev up on its own and go back to normal idle. But which one would it be or both of them? thanks das
Old Sep 10, 2007 | 01:32 PM
das2123's Avatar
das2123
You can pull the IAC and give it a good cleaning and also clean the TB while you are at it.
Old Sep 10, 2007 | 05:37 PM
RiceBoy_88's Avatar
RiceBoy_88
What is theIAC and where is it? NEVERMIND IAM A DUMBASS
Old Sep 10, 2007 | 05:44 PM
Slashwannabe
Question....
Will the Throttle Position sensor causelow endpower to be inconsistant?
