how hard is it to instal the UDP
Old 09-14-2007, 08:52 AM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
Default RE: how hard is it to instal the UDP
well for the amp sucking it hits F-ing hard way harder then the 4000 wattt i had
its a 2 channel 1200 watt and i have each 1200 watt sub hooked to a channel
and its pretty damn loud for only being 1200 watts
so unless you were saying 500 watts achannel then you would be correct but 500 watts total would be 250 watts a channel
but im upgrading to pioneer subs probely
there at my radio shack for like 240 bucks for 2 -12's with enclosures but idk .. ill get some pics and let me know what you think about that series
  #22
Old 09-14-2007, 08:57 AM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
you cant tell me brand doesnt make a differance...
the kid has like 2-300 watt Kickers hooked to a 2 channel 300 watt and it hits pretty good almost as good as mine...
andi have 2400 watts worth of subs hooked up to 1200 which i figure is pushing just right becuz its 1200 watts max and prolly like 500 or600rms
  #23
Old 09-14-2007, 09:25 AM
12 volt's Avatar
12 volt
12 volt is offline
exacly what subs and amps do you have (model #).
sometimes there can be a big diffrence in RMS watts and max watts. im guessing your running 4 OHMS to eash channel
just stay with your setup as long as your happy with it who cares what brand it is.
  #24
Old 09-14-2007, 09:48 AM
12 volt's Avatar
12 volt
12 volt is offline
hey 12v whered u get your rear disc conversion??
oooohhhhh yeah ..............i got then from my 96 sport (parts car) search can get you some better info on that topic
  #25
Old 09-14-2007, 01:17 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
you may have 1200 watt subs....but that doesnt say too much...
the sub can handle a max power of 1200 watts, but thats peak not rms....the subs will actually blow long before you are ever able to get 1200 watts to them because of the distortion the amp puts out
if you have a 2 channel amp with 1 sub hooked to each channel then the amp is probally only pushing out about 400 watts peak per channel which would be roughly about 200 watts rms since the subs should be running at 4 ohms.....
  #26
Old 09-14-2007, 03:00 PM
estneon's Avatar
estneon
estneon is offline
hey what is the perfect system im just about ready to buy mine for the bonneville
  #27
Old 09-14-2007, 09:11 PM
spudsterier
there are only a few companies that are reliabe on the power ratings.....audiobahn is pretty good, but orion is awsome, or if you can find an old school PPI amp......i like my pheonix gold, but it wouldnt of been my 1st choice......
ignore what the power rating of the amp is and go by the fuses....the more fuses and the higher the amp rating of them, the more power it has
  #28
Old 09-14-2007, 11:43 PM
Aerorat's Avatar
Aerorat
Aerorat is offline
ORIGINAL: spudsterier
Spud i don't mean to argue with you but that fuse comment the more fuse now a days is a cheaper power supply.
  #29
Old 09-15-2007, 08:36 AM
spudsterier
thats why i try and stay away from new amps......
  #30
Old 09-15-2007, 11:52 AM
boxerjl2's Avatar
boxerjl2
boxerjl2 is offline
i like what 12v said... but i really dont care how many watts im putting into cuz i know its loud... but my amp has 2, 40 watt fuses but this amp was given to me so i cant complain about it...
how about Boss are they reliable cuz i have a 1200 watt monoblock is that a good amp??
Quick Reply: how hard is it to instal the UDP
