Indy Intake Manifold
Old Sep 19, 2007 | 10:43 PM
  #21
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Indy Intake Manifold
I thought the SOHC intake manifolds were good though because they were plastic and had long runners...
Old Sep 19, 2007 | 10:52 PM
  #22
spudsterier's Avatar
spudsterier
they arent bad, because the plastic ones are atleast smooth inside, but the runners arent very large in diameter
Old Sep 20, 2007 | 08:53 AM
  #23
das2123's Avatar
das2123
ORIGINAL: spudsterier
find one of the aluminum intakes manifolds from the 95 sohc's......then port it out
And polish it as well. That might be my next step after swapping my ported and polished head onto my ACR
Old Sep 20, 2007 | 09:52 AM
  #24
98Neon4Door's Avatar
98Neon4Door
Aight well ran into some finacial issues and wont be ordering the manifold till the end of the month
The whole reason I wanted to get the indy was because right at the moment I have a Dime sized hole in the intake by the TB that is filled with an epoxy type sh*t. Now that works for right now but about the time that gives way and gets sucked into the motor... thats really gunna **** me off. And next year I also plan on rebuilding the SOHC and putting on hahns turbo setup.
Old Sep 20, 2007 | 07:31 PM
  #25
AMM's Avatar
AMM
ORIGINAL: estneon
is there a discount for people in az
where are u in az?
and yeah u get 30.00 off cause i wouldnt have to ship it to u.
extrude honed aluminum stocker- to expensive and results are notvery impressive
mag- kinda pricey and takes a bit of work to get it tooperate properly
indy- overpriced and results are not very impressive............ unless ur turboed or making lots of power in N/A form
mike
Old Sep 20, 2007 | 11:10 PM
  #26
estneon's Avatar
estneon
close enough to pick it up[8D]...hell i would rather see your neon
Old Sep 21, 2007 | 09:55 AM
  #27
AMM's Avatar
AMM
ORIGINAL: estneon
nothing special about it............ completly stock bodied 95 with lots of dings, dents, scratched etc. black 16" eneki wheels and a stock bottom end 2.0 sohc with a mildly ported head, crane 14 camand a mopar computer. after im done with my current orders i will then build an intake for my car and throw on my 60mm t-body on. eventually i will build a header and an exhaust and thats gonna be all she wrote for my DD.
