sohc- dohc switch over
Old 09-20-2007, 06:05 AM
Slashwannabe's Avatar
Slashwannabe
Slashwannabe is offline
Default RE: sohc- dohc switch over
The DOHC block and the SOHC block are the SAME CASTING NUMBER.
The heads will fit on each other.
The DOHC PCM provides more gas than a SOHCPCM does so therefore its better if you are using a Turbo.
The DOHC PCM from an Automatic is a ***** it redlines at 5800 Rpm but with a Turbo you wont need to push your car that high....lol because you should have won the race allready.
Your SOHC PCM for an Automatic might actually redline Higher than a DOHC Automatic Pcm.
The Manual PCMs of either the DOHC or SOHC is what you want if your going for a higher redline.
Old 09-20-2007, 06:58 AM
racerx55's Avatar
racerx55
racerx55 is offline
and you cant use a turbo in any of these stock 4 cyl race classes.
they outlawed it because its unfair,...a turbo 90 talon won the pure stock feature after killing the rest of the 4 cyl class all year.
Quick Reply: sohc- dohc switch over
