which ecu should i go with
Old Sep 21, 2007 | 09:37 AM
boxerjl2's Avatar
boxerjl2
Default RE: which ecu should i go with
for the af/x do you still need to use the differant gas??
Old Sep 21, 2007 | 11:41 AM
das2123's Avatar
das2123
ORIGINAL: boxerjl2
Requires the higher 93 octane I believe.
Old Sep 21, 2007 | 04:03 PM
dirt_trac_racer_80jr's Avatar
we run sunoco 115 in the neon .....its some potent **** ...i noticed a huge difference in power just by using it ....but at 6.75 a gallon its probably not wise to run it on the road
Old Sep 21, 2007 | 08:35 PM
racerx55's Avatar
racerx55
i found that i made more power on 93 or 92 pump gas, with a 160 stat. 115 it just dont have the compression to burn it right. keeps your timing from retarding but it also creates more heat. cooler engine temp with a 50/50 mix even made really good power. i ran a big 3/8 mile track and ran 3rd gear to 7700, once in a great while id hit the rev limit. ****in fast, i loved it.
Old Sep 22, 2007 | 02:05 AM
12 volt's Avatar
12 volt
Octane rating is a measure of anti-detonation of a gasoline. This is needed because of more aggresive spark advace that come with aftermarket PCMs
http://en.wikipedia.org/wiki/Octane_rating
Old Sep 22, 2007 | 05:08 AM
i cant inagine running in third gear on a 3/8 mile ...it unheard of around my parts ... im goin to run the hershey show this year on a 1/2 mile its 2000 to win and im lookin forward to it. its also ran like a nascar event ...its a 2 day event and you have to qualify....its goin to be a blast ..u should look it up and then we could meet in person
