Purple Ronnie dies again!!
Old Sep 25, 2007 | 06:37 PM
Dagenhamgeoff's Avatar
Dagenhamgeoff
Default Purple Ronnie dies again!!
Hiya folks, been searching everywhere for answers but nothing. Been having a few issues with the car but thought I solved them.
Got SOHC 1998 auto, problems go like this:-
Starts up with no problems, idling at approx 1k which I figure is kinda ok, rev up and still no problems, put into reverse it sputters and dies, if I go from Park to Reverse it dies, if i go from Neutral to reverse it dies and if I go from drive to reverse it dies, it usually starts right up again but if i leave it idling for 10 - 15 minutes it dies and won`t start.
New coil, plugs, wires and air filter but still problem not solved.
No codes, did start with 11 but replaced cam and crank sensors.
Read on here somewhere to check ATX fluid, it was low so added to warm/hot, now when I shift into any gear it kinda bolts, like aggressive change, figured it might be torque convertor going ape but not sure, any ideas??
Other thing is could it be the fuel pump going, I can hear the pump moving when I first start but again read on hear that if theres not much fuel and the pump is going bad it will shut down, as it is I`ve about 1/4 tank but yet can still hear pump.
I`m totally confused with it all so if anyone can help I`d be really grateful
Geoff
Old Sep 25, 2007 | 06:48 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Purple Ronnie dies again!!
Sounds like a throttle positioning sensor, or a idle air control sensor.
Old Sep 25, 2007 | 08:23 PM
sxybrod's Avatar
sxybrod
what does the idle air control sensor do and how does the car run if its bad?????
Old Sep 25, 2007 | 08:37 PM
Jr. Mechanic
ORIGINAL: sxybrod
That would also be the same thing as a MAP sensor
Old Sep 26, 2007 | 08:48 AM
das2123's Avatar
das2123
^^^ IAC is Idle Air Control Motor and is located on the throttle body. IAT would Intake Air Temperature sensor which is combined with the MAP sensor.
Old Sep 26, 2007 | 08:53 AM
sxybrod's Avatar
sxybrod
basically same thing thats wrong with my car right now just a different name for it ok i think i get it now sorry i know a little about cars i can change a tired tell you if your fuel pumps not working and change my own oil but sensors and car computers are not my thing im afraid
Old Sep 26, 2007 | 03:36 PM
Jr. Mechanic
ORIGINAL: das2123
[:@] Darn... Dont know what I was thinking... I know that...
Old Sep 26, 2007 | 03:38 PM
das2123's Avatar
das2123
It was early.
