power gains?????????/
Old Oct 9, 2007 | 12:12 PM
noenwarrior's Avatar
noenwarrior
Default RE: power gains?????????/
when i ran sohc i picked up a dohc computer and i could tell the difference plus my rev limiter went from like 5600 rpms to bout 7200 rpms.
Old Oct 9, 2007 | 03:31 PM
Slashwannabe's Avatar
Slashwannabe
ORIGINAL: noenwarrior
The Rev Limiter on my DOHCPcm for use withanautomatic transmission was 6,000 Rpm, Kinda sucks but its ok, its scarey to go up to 6,000 Rpm with a stock Engine.
Old Oct 9, 2007 | 04:43 PM
Jellysrus's Avatar
Jellysrus
i have a mtx with an atx tb it makes a differance more so when you puta new intake on at the same time you can really tell the tb that i got also has a lot more throttle response than the mtx and also i get a little better mpg
Old Oct 9, 2007 | 06:40 PM
noenwarrior
i ran over 7k rpms all the time on the stock block and it seemed to like it lol guess it didnt like a granny driver.
Old Oct 9, 2007 | 08:24 PM
jfink's Avatar
jfink
i guess i'll go with the atx throttlebody along with the dohc pcm if i can find one cheap. i'll get my downpipe on friday. so with all those combined i should be content for now.
Old Oct 9, 2007 | 09:46 PM
noenwarrior
well ur gonna like the outcome of those cheap mods there also I do make a ported intake manifold http://www.cardomain.com/ride/273730/1 page 8 bout half way down ull see the difference and makes a difference.
Old Oct 10, 2007 | 09:49 AM
das2123's Avatar
das2123
ORIGINAL: Slashwannabe
The best power gain I got from my stock DOHC pcm was 5hp says the Gtech.
Until I see this proven on a dyno, I am going to have to disagree. The Mopar PCM adds about 5 HP, so I don't see the stock DOHC PCM adding 5 HP.
ORIGINAL: Aerorat
Uh the atx throttle body does add alittle horsepower. It is like 5 to 10 horsepower and i think it is closer to 5 hp.
Nowhere near 5HP....maybe 1-2.
Old Oct 10, 2007 | 07:58 PM
Slashwannabe
ORIGINAL: das2123
LoL The Gtech gets no credibility....
Well I only am so grounded in this belief only because the gains were consistant with the PCM swap,My original PCM had a software updatethat was given in2001 so who knows what was done to the pcm in the way of flashing, it says it was done by a Chrysler Dealer.
But there is no denying putting the DOHC pcm boosted 5hp on the Gtech over my baseline power on my specific car with my specific setup, and it also achived in the 4500-5500 Rpm range. I've done over 10 tests to average out a baseline and they were consistant to within 2hp from each other, now fast forward to the DOHC pcm swap and I've got a consistant margin of 5hp gains with multipul test runs to confirm.
I think we need to get the Mythbusters on this onebecause I don't have any cash to Dyno a stock motor.
I understand the Gtech isnt the gosipel but it gives a very close ballpark answer and is acurate enough to tell when you add something that increases performance. It worked very well in acuratly predicting what the power of my Brothers Turbo Acclaim had, and guess what it was within 2hp of what the car really made from the factory. The funny thing is I'm seeing that same consistant reading with my car and the factory ratings and even its use on my parents van.
Old Oct 10, 2007 | 08:35 PM
spudsterier's Avatar
spudsterier
its just hard for me to believe that sumthing like that can be so accurate by just plugging into the cigar lighter and not into the obdII port or anything else...
it wouldnt of been updated with anything special.......usually they get updated because of a TSB for a misfire
Old Oct 10, 2007 | 09:55 PM
Slashwannabe
ORIGINAL: spudsterier
My Dohc pcm wasn't updated at all thats why I was wondering if that may be why it produces a little bit more power, I figured they might have tuned the pcm for economy in the update,but thats probably not the case.
I was very skeptical of the Gtech till I got to use it myself and research. You might gain some confidence in it after I tell you how it works...
What it has you do is set the weight of your car and it references that to pre determinedHP figures G'sxWeightto get its readings. Basically it refferencesHow much Hp it takes to create certain G's at a given weight and it gets the G information when you accelerate. When I'm in my Neon with a full trunkthe carweighs 2810lbs, I weigh 245 now so what ever the car weighs without me and a full trunk I don't really know, but I have the good fortune to be able to weigh my car at a local junkyard scale plus refference the door Stickerweight and thats how I set up my Gtech.
The thing is really cool it even has a sensor that acuratly determines quarter mile distance and time within a 10th of a second. My best Quarter mile time with my Neon was 16.5 with the old tranny with worn clutches. I'm not going to test my quarter mile with new tranny till I get 2nd Gear working,But my first gear is pretty damn snappy now, I can take Chevy's off the line now!
