T3 or 16gs the question?
Old Oct 6, 2007 | 05:58 PM
jfink's Avatar
jfink
Default T3 or 16gs the question?
plan on turbo charging my neon in the spring and trying to figure out which turbo to go with i heard good things about the T3 and the 16g turbo's. anybody know a thing about these turbos that might be helpful?
Old Oct 7, 2007 | 01:07 AM
12 volt's Avatar
12 volt
Default RE: T3 or 16gs the question?
pretty shurT3 is just a flange size for garret.
http://www.forcedinductions.com/help.htm
16gmitsubishi turbo??? better off going with the SRT4 turbo im my opinion
Old Oct 7, 2007 | 07:36 AM
Slashwannabe's Avatar
Slashwannabe
ORIGINAL: 12 volt
Can we go one thread without hearing that dreaded pipe dream words "SRT-4" OMG.
The best all around Turbo is the T03 Garrett which is capable of providing up to 25psi of boost while providing consistent gains from idle to 6,500 Rpm+.
Garrett Turbo Vs Mitsubishi Pros and Cons
Mitsubishi Turbo Pro's-
Has extremely good spool time which ads to low end punch, Small easy to fit turbo.
Mitsubishi TurboCon's-
PowerFades out Rapidlyafter 4,500 Rpm and its pretty much up to your engine alone after that.
Garrett Pro's-
Unlike the Mitsubishi Turbo the GarrettIs very Consistent through the power band and never flat lines or stops pulling and will produce more overall and peakpower from your engine, Alsohas a well designed oiling and cooling system for longer life and roller bearings on its shaft. Even though it is quick at spooling and delivers usable power at 1500-3000Rpm, It is at 3500 Rpm+where you will thank yourself for going Garrett.
Garrett Con's-
None really! Except it isNot as quick as the Mitsubishi Turbo in initialspool time (more than makes up for it after 1500 Rpm) Note: Adding an intercooler and jacking the boost upto around 12psidoes reduce the lag quite a bit and nearly eliminates this problem.
Old Oct 7, 2007 | 02:47 PM
12 volt's Avatar
12 volt
the only reason i would say that is beacause if your going to get a garret it's not going to be cheap.
SRT4 stuff is cheaper and easyer to install.
Old Oct 7, 2007 | 05:47 PM
spudsterier's Avatar
spudsterier
the srt4 turbo is a mitsubishi also
Old Oct 8, 2007 | 08:53 AM
racerx55's Avatar
racerx55
i love my 16g, if you would get one, dont get a small or big 16g, or the chinese / tiawan GT or "super" 16g, get a REAL EVO III 16g. that turbo pushes DSM's well into the 11's. clipped and ported they will go alot farther than 4500 rpm, mine begins to drop off at about 7000... its all in your setup.
the T3 is more expensive but an awsome turbo for sure.
SRT4 turbo is a piece of crap in my book just because ofthe manifold and turbine housing being all one piece.
Old Oct 8, 2007 | 09:07 AM
estneon's Avatar
estneon
im getting a 20g turbo/manifold and down pipefrom hahn for a srt-4to put onthe stratrus and nowa 16g from a evofor the neon...thanks to racerx55'sidea i will save a buck
Old Oct 8, 2007 | 09:24 AM
racerx55's Avatar
racerx55
how much HP and boost are you lookin at? the 16G will do 25 all day and close to 400 HP motor.
you can also buy two 16g's for the price of one 20g
Old Oct 8, 2007 | 09:56 PM
estneon's Avatar
estneon
400hp-500hp on the stratus....im getting the kit for the srt-4 it hasbetter flow in the manifold and the 20g is only $50 more then the 16g 'in the kit' so what the hell i will upgrade now and save a little money down the road....and i just learned i need custom axles....sothati can handle 500hp[8D]i'll make sure it can servive 650hp to be on the safe side
Old Oct 8, 2007 | 10:14 PM
spudsterier
ORIGINAL: estneon
hahns prices for anything are completely outrageous.....after finding out that they charge $600 just for a turbo exhaust manifold, i kinda lost interrest in them
