my fault of the shops fault??????
To me, it looks like defective rings, or, did the shop bore the motor out any? It looks like to me they were not within tolerances for that size piston and ring set so it was tight from the time you put it in, honestly I do not see anyway you personally could have done that. I have put together plenty of motors and it is hard to screw something up that bad. Take the block and pistons to another machine shop and see what they have to say, it is always good to get professional opinions.
well i took the block and pistons back to the shop that did the engine work this morning.....
the guy said that it looks like the piston was sticking to the cylinder wall....he also said that it looks like ther wasnt enough clearance between the piston and wall.....he said the normal clearance is about .0005-.001 well when i told him that the paper work said thy should have .004 clearance, he seemed shocked that they called for that much....
so, he is gonna check it all again, re hone it, check the clearaces, and re bore it if he has too....atleast that part isnt costing me any more money....but it might be awhile until he gets to it[:@]
now im gonna have to buy 1 new piston..$125....all new gaskets....~$ 150......and new rings....$100
atleast i dont have to pay for the block work though
hopefully within a month or 2it will be back up and running...unless i get lucky
ORIGINAL: Jr. Mechanic
i think thats should be some good news though. even though it dosent sound like they took responsibility for it ... in a sense they are byshowing they need toredothe new work for you... hopefully you will get it back up soon.
from the sounds of it at the shop the guy didnt want to say it was his fault, but i think he knew.....
it sux that i still have to replace the piston and all the other junk, but atleast i am saving money on having to get the block redone
Hehe, I was right! I would fight like hell to have them pay for that piston and rings, maybe be reasonable not to make them pay for the gasket set, but that was a result of their negligence.
they did have all the specs from JE....the shop had the block, pistons, rods, bearings and everything else....the paperwork stating the specs of the pistons was in the box with them.....they had everything that i had
now that you haveeverything taken apart maybe you should consider piston coatings.
http://www.dicustomcoatings.com/piston.html
http://www.swaintech.com/store.asp?pid=10296
