frankinmotor need help
Old Oct 10, 2007 | 02:40 PM
das2123's Avatar
das2123
Default RE: frankinmotor need help
Compression test would test the valves. Once you pull the head off, you can have a look at the block. Yes, you will need a new HG. Might as well change the timing belt, water pump and idler pulley as well. I can list where I got all my parts from as I just did this a couple of weeks ago.
Old Oct 10, 2007 | 02:42 PM
romeo21's Avatar
romeo21
man that would help out alot thanks
Old Oct 10, 2007 | 02:51 PM
das2123's Avatar
das2123
*HG kit from Modern Performance...$99 shipped.
*Gates Idler Pulley from www.rockauto.com, part #T41002 $21.79
*A-1 CARDONE from www.rockauto.com, part # 58522 $21.79
*FEL-PRO head bolt set from www.rockauto.com, part # ES72157 $31.79
And I got a Felpro timing belt from my local Autozone store.
Old Oct 10, 2007 | 03:09 PM
romeo21's Avatar
romeo21
do i need to buy new sencers or can i just swap out the ones that are on it and can i use the old timeing belt i put int on like 3-4 months befor i blew it oooo and if there is a bit of rust on the valves do i have to take it in to a shop or is it something i can do
Old Oct 10, 2007 | 03:48 PM
das2123's Avatar
das2123
You can swap the sensors as long as they plug into your wiring harness.
Old Oct 10, 2007 | 03:50 PM
12 volt's Avatar
12 volt
as long as its not on the valve seat, or any of the guides i should be negligible.
Personaly i would have the head tolerances checked at a shopalong with valve stretch, regrind seats, repace valev guides, spring tensions ect . But that just me.
Old Oct 10, 2007 | 04:15 PM
romeo21's Avatar
romeo21
ok how much do you think all that will cost
Old Oct 12, 2007 | 12:00 PM
romeo21's Avatar
romeo21
ok well i went junkyard hopping yesterday and cam by a dodge 2.4 stratus dohc now how hard would that be to swap that into my 96 what would i need all it has on the motor is the wiring hannesand would it be worth it
Old Oct 12, 2007 | 09:51 PM
romeo21's Avatar
romeo21
need help
Old Oct 13, 2007 | 12:16 AM
das2123's Avatar
das2123
Help is already here if you look....
https://dodgeforum.com/m_859980/tm.htm
