Automatic Shut Down relay, it kills the spark and injectors in the event of an accident. This is why you should do what I said with the coil pack connector, also, pull out the fuel rail and turn it over and see if they are spraying out gas.
u know its funny you mention that cause i switched my relays all around the night that it started... but then the car ran for 15 minutes then died again... so could something be shorting out my relay constantly? im so lost right now lol
