Replacing Brakes on a 96 Neon
Are you wanting to replace the brake pads? If so, it's very simple!
*Take the tires off
*Remove the (2) bolts for the calipers...10mm I think.
*Remove calipers and remove old brake pads
*Take the brake fluid cap off, and use a C-clamp and a small block of wood to push the caliper piston back in
*Install new brake pads and reinstall calipers.
*Take the tires off
