No fuel
Old Oct 15, 2007 | 11:13 PM
waterman77's Avatar
waterman77
Default No fuel
I am wondering if anyone has a wiring diagram for a 1997 Neon 2L SOHC.
Specifically the fuel system.
Thanks
Randy
Old Oct 16, 2007 | 02:25 PM
12 volt's Avatar
12 volt
Default RE: No fuel
pin 55 in you relay is always hot, this closes to pin 52DK GRN/WHT wire that goes direct to the fuel pump and toground.
If you what the diagram your going to have to buy a maintenance manual.
Old Oct 17, 2007 | 11:26 AM
waterman77's Avatar
waterman77
Default RE: No fuel
Thank You I will try that
Old Oct 26, 2007 | 11:42 PM
waterman77's Avatar
waterman77
Default RE: No fuel
OK I am going to look at this again tomorrow. ( To many irons in the fire right now. )
I have a simple wiring diagram. In doing a lot of reading it appears that a bad ground is often the cause of electrical problems. Is there any common ground issues with the fuel pump that you are aware of ? I am just wondering that I am not overlooking the obvious. Also I am concerned that when run a jumper from pin 55 on the relay socket to pin 52 on the socket and it doesn't work where to look next.
Thanks for your help
Randy
Old Oct 30, 2007 | 03:19 PM
waterman77's Avatar
waterman77
Default RE: No fuel
OK I have done some more testing on the car. I tested the dk grn \ wht stripe wire at the fuel pump connection ( with some help of course )and when I turn the key on I have voltage for aprox 2 - 3 seconds then it drops off. I understand this is normal until the car is running. There is the problem the car never starts. So I guess I am looking for a way to test the fuel pump at the 4 wire connection at the pump. I would like to be sure it is bad before I go spend $$$$ on a fuel pump.
Thanks
Randy
Old Oct 30, 2007 | 04:23 PM
12 volt's Avatar
12 volt
Default RE: No fuel
to test the pump you apply 12 volts to DK GRN/WHT wire. its a good idea to use a 20 amp fuse in series with your jumper wire.
Old Oct 30, 2007 | 05:39 PM
waterman77's Avatar
waterman77
Default RE: No fuel
If I send 12 volts to that wire should I hear the fuel pump run ?
I mean while I am under the car near the fuel pump.
Old Oct 30, 2007 | 08:52 PM
12 volt's Avatar
12 volt
Default RE: No fuel
yes...... you should have approximately49 psi at the fuel rail
