starter
Old Oct 17, 2007 | 06:38 PM
pssssst's Avatar
pssssst
Default starter
will a car crank over if it has a bad starter?? also, are the sohc and dohc starter the same in case i need one??? thanks
Old Oct 17, 2007 | 09:42 PM
spudsterier's Avatar
spudsterier
Default RE: starter
the sohc and dohc starters are the same.....only difference may be the years...95,96, nd some 97's have 1 different plug then some 97's, 98, and 99's
if the car turns over then the starter should be fine
Old Oct 18, 2007 | 01:35 AM
pssssst's Avatar
pssssst
Default RE: starter
thanks spud
