mopar pcm?
ORIGINAL: 95neonriceeater
yea but there is the other side of things where the companies make computers just for turboed cars
there just isn't one for our cars!
Some PCM's are tunable, but the neon one isn't. Thats why we have to use a MAP clamp or missing link to keep the PCM from seeing boost.
ORIGINAL: das2123
Not neccesarily, you can use Megasquirt as the PCM
ORIGINAL: Slashwannabe
Explian the map clamp and missing link... how it works.... Its greek to me...
http://www.racingworks.com/missinglink.htm
Trending Topics
a map sensorsees the voltage change from more pressure in the manifold and it only sees vaccum not boost and adjusts the air and fuel to correct the problem....
a map clamp holds the map sensor at its highest voltage but wont let it go any higher...and then hides the boost from the pcm.......basically
